Bas Vellekoop
Modeling question, fillet the corners of two intersecting nurbs surfaces
Well, in Microstation's implementation of Parasolid from a decade or more ago
you would find such in Surface Tools.
If in VW there is no way to combine/stich both Surfaces and apply the fillet Tool
in any way, in this special case it looks like a simple extruded Profile so far.
Maybe  the Fillet Tool would work on a simple 2D-ish Extrude ?
Another option would be SubD with "helper Edges" to control the Radius of that
bevelled Edge and finally converting back to NURBS if it should get more of a
free form later.
(Can test as VW is rendering)
2 minutes ago, Jim Wilson said:
Do you mean something like this? I may have misunderstood which edge/direction you were looking for:
Very good idea to give it a (little) Thickness before ....
Edited by zoomer
If thats what hes going for, but didnt want the FINAL to be flat, its always possible to extract the bent/filleted surfaces and then youll be back to NURBS surfaces with no thickness. However, I shelled the original NURBS outward, which would make the resulting extract from this a bit too large, had i shelled them inward the exterior face would have maintained its original dimensions.
a very fast sketch 🙂
Hope this explains what i want 🙂
@Jim Wilson @zoomer
I`m able to do it is the following way,
Shell the nurbs surfaces, fillet the edges, and then extract the inner surfaces again and shell them again.
Edited by Bas Vellekoop
Ahh I see now, much tougher. Especially defining a particular fillet since it curves in 3 axes, I'll poke at it some more and see what I get.
Yeah I know, but when possible very nice.
The way i did it now is through a detour. I would be beter if it was possible on the nurbs sufaces.
I thought i was maybe possible with the fillet tool from 2d pallet. I thought it worked on nurbs curves as well, but not sure.
Hmmh,
so to create the whole thing from a Generic Solid first,
which has a stacked Body form so you can get your "Profile Shape"
by carefully using Fillet Tool,
(Like to get your single Arc by filleting 2 Edges until they meet and such)
Subtracting a Volume from that vertical Edge,
(so it looks like a bended Sheet Metall Body)
Finally Extract the Faces again ?
1 hour ago, Bas Vellekoop said:
Hi guys,
Is there a possible modeling technique in which it is possible to fillet the 2 edges of these nurbs surfaces and give them a radius of lets say 10mm?
@Jim Wilson You maybe any suggestion?
fillet edges.vwx
I would try Model>3D Powerpack>Create Fillet Surface.
 http://app-help.vectorworks.net/2019/eng/index.htm#t=VW2019_Guide%2FShapes2%2FCreating_a_Fillet_Surface.htm&rhsearch=fillet surface&rhhlterm=fillet surface&rhsyns=
Its a bit finicky and you may need to flip the normals or perhaps rebuild a surface using Rebuild NURBS.
Kevin
For the first part,
for me works well :
- Create an Arc + a Line
- Compose
- Extrude
- Apply Fillet Tool for the Edge
Of course I could have created a Polyline in one go for the Profile to extrude.
But it is nice that VW Fillet works on 2D Extrusions ....
Edited by zoomer
EDIT
OK, asking for that thing above to convert into a SubD - was too much.
And I don't know really what I can do with 3 separate NURBSies when converted.
3 hours ago, zoomer said:
For the first part,
for me works well :
- Compose
- Extrude
I might use this method too. You could then draw the angled edges and rounded corners on the flat surface and trim them off using the Project tool.
Kevin
I read that such 2D-ish Objects could be cut by 3D Solids too, never tried.
And the Eraser and Cutter Tool often do things in 3D that you would not expect too.
But I think these 2D-ish are a bit of a blind alley.
When converted to Solid it seems to destroy the roundness and make it polygonal.
At least when I Thicken it with the Shell Tool.
One side stays round, the other side gets polygonal.
Just like in the past when I cut my Cylinder Columns from a Floor Solid.
As soon as edited the round wholes got Mesh-y
Edited by zoomer
- Compose
- Extrude
Ah, I misread your instructions. I would fillet the composed Polyline and then extrude.......
KM
Yes, staying 2D as long as possible for me seems to be always a good idea.
