Developer Wiki and Function Reference Links Read more... ×
IJSSEL
Pop up Node, How to ?
I would like to replace the Integer Dialog node with a Pop-up node. Let say 5 inputs and 5 outputs.  : input ==2 , output = 1680, or input == 3, output = 2520 etc.
I can not find an example of how to write the script for the Pop-up node to implement  this, so I came up with this (See attachment), but the input does not generate an output.
Help is much appreciated, thanks. (I'm new to Marionette, but that is obvious :-)
Problem solved! I should have skipped the last 2 lines of script :
#outputs
self.Params.output.value=input
