tismacfan2 Posted November 1, 2018 Share Posted November 1, 2018 When I place a sheet border it is always drawing in the active class. Is there a possibility to draw it in a pre choose class? thanks Pascal Quote Link to comment
Kevin McAllister Posted November 1, 2018 Share Posted November 1, 2018 Often the default class for tools can be set using the menu command Tools>Plug-ins>Plug-in Manager and choosing the tool from the Built-In Plug=ins pane. Unfortunately it looks like default class is greyed out for the new Title Block Border ( @Nikolay Zhelyazkov is there a reason why the default class cannot be set this way. Is there another way to set it or is this something that could be a wishlist item? ). If you're still using the Sheet Border tool (VW2017 or earlier) it looks like its default class can be set. It seems to be called Drawing Border - Universal in the Plug-in Manager. Click on it, then the Customize button and switch to the Properties tab. Kevin 1 Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted November 1, 2018 Vectorworks, Inc Employee Share Posted November 1, 2018 Hello @Kevin McAllister, 6 minutes ago, Kevin McAllister said: Often the default class for tools can be set using the menu command Tools>Plug-ins>Plug-in Manager and choosing the tool from the Built-In Plug=ins pane. Unfortunately it looks like default class is greyed out for the new Title Block Border Thanks for pointing this out. I will see what could be done about it and keep you informed in this thread. Best Regards, Nikolay Zhelyazkov 1 Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted November 1, 2018 Vectorworks, Inc Employee Share Posted November 1, 2018 Seems like setting the default class is possible only for some of the script plugins. As the Title Block Border is not a script plugin, this is not available for it. @Kevin McAllister you could add a wish, if you want to. 🙂 1 Quote Link to comment
tismacfan2 Posted November 1, 2018 Author Share Posted November 1, 2018 maybe they should make it possible to choose a class in the settings of the border. Pascal 1 Quote Link to comment
