Associations equivalent in C++
Cmb
Hello !
I'd like to know if there is an equivalent as this method in Vectorscript in the SDK
AddAssociation(obj1, kOnDeleteDelete, obj2);
or what is the best way to have the same behavior, as I want to delete a child when an Object is removed.
I also tried to catch the event in VWParametric_EventSink, but can't find a virtual for that.
Is there a way to do this without having to override :
virtual Sint32 VCOM_CALLTYPE	Execute(ParametricMessage* message);
Thanks
You can add an association with Kludge.  I couldn't find a way to remove an association, so I call VS.
    void AddDeleteAssociation(MCObjectHandle FromObject, MCObjectHandle ToObject)
        PluginLibraryArgTable argTable;
        argTable.args[0].argType = kHandleArgType;
        argTable.args[0].handleValue  = FromObject;
        argTable.args[1].argType = kIntegerArgType;
        argTable.args[1].intValue   = 4;
        argTable.args[2].argType = kHandleArgType;
        argTable.args[2].handleValue  = ToObject;
        EPE_Kludge in( EPE_Kludge::kKludgeAddAssociation, & argTable );
        ::GS_Kludge( gCBP, EPE_Kludge::kKludgeSelector, & in, nil ) && argTable.functionResult.boolValue;;
    void RemoveDeleteAssociation(MCObjectHandle FromObject, MCObjectHandle ToObject)
        argTable.args[0].handleValue  = ToObject;
        argTable.args[2].handleValue  = FromObject;
        gSDK->CallPluginLibrary("RemoveAssociation", &argTable, 0);
If you want to handle deletions on the event level, look at the UpdateSupport example in the SDK.  The update manager runs independently of the plug-in objects, so it can handle deletions.
