RobbieButler
VW2019 - Spotlight Numbering
Hello!
I'm having trouble using the new spotlight numbering tool in VW 2019.
I can't seem to get fixtures to take the channel info. I've attached a video of the problem.
Any ideas?
Rx
Edited by RobbieButler
added video
Currently you have no instruments selected so you will need to manually select each instrument in turn when you click OK. Double-click on a blank area to end the command.
If you select the instruments beforehand, then you will see the Numbering Direction section un-greyed and you will then be able to number your instruments using the criteria there.
I hope that helps
Mark
Edited by markdd
I hope that helps
Mark
Hi @markdd,
Thanks for the response  - yep, that's what I've been doing, but it doesn't seem to work.
Rx
It doesn't look like it is behaving itself quite the way mine does. Add a label legend to it and see if the channels numbers are entering the same as mine are before you end the tool command. Are you double-clicking at the end? If you are not, then you should be.
There's already a label legend on it. Which works when manually inputting information. I'll try restarting it and see if that works...
Rx
Unless you are very far down the line, I suggest you import all the work you have done so far into a clean file and work on from there. A layer import is best IMO. There may be other issues down the line...
Did this drawing originate from a different version of Vectorworks?
Nope, it started in 2019.
I haven't changed anything, but closed the program and restarted it again before importing - that seems to have done the trick! No import required.
Odd, I haven't changed anything since the last time I restarted.
But problem seems to be solved!
Thanks Mark!
Rx
