Scale bar text not showing in VWX 2019
EvelyneB
Hi,
I just upgraded to Vectorworks Architecture 2019, and for some reason when I add a scale bar the numbers don't show up. I tried this in an existing file, mucked around with class & layer visibilities to no avail. I also created a blank file and added a scale bar, and had the same problem there. Is this a 2019 bug? Has anyone else encountered this issue?
24 minutes ago, EvelyneB said:
Hi,
The Scale Bar works fine for me. Since upgrading to VW2019 have you set the default font using the Text Menu? Try the following -
  1. Deselect everything.
  2. Go into the Text Menu and set your Font (type, size etc.).
  3. Try inserting a Scale Bar again.
Kevin
