EvelyneB Posted October 25, 2018 Share Posted October 25, 2018 Hi, I just upgraded to Vectorworks Architecture 2019, and for some reason when I add a scale bar the numbers don't show up. I tried this in an existing file, mucked around with class & layer visibilities to no avail. I also created a blank file and added a scale bar, and had the same problem there. Is this a 2019 bug? Has anyone else encountered this issue? Quote Link to comment
Kevin McAllister Posted October 25, 2018 Share Posted October 25, 2018 24 minutes ago, EvelyneB said: Hi, I just upgraded to Vectorworks Architecture 2019, and for some reason when I add a scale bar the numbers don't show up. I tried this in an existing file, mucked around with class & layer visibilities to no avail. I also created a blank file and added a scale bar, and had the same problem there. Is this a 2019 bug? Has anyone else encountered this issue? The Scale Bar works fine for me. Since upgrading to VW2019 have you set the default font using the Text Menu? Try the following - Deselect everything. Go into the Text Menu and set your Font (type, size etc.). Try inserting a Scale Bar again. Kevin Quote Link to comment
