jcl Posted September 16, 2003 Share Posted September 16, 2003 I cannot generate a dtm. I have imported as both 3-d, and 2 & 3-d. Depending on the import, I get a message of miscellaneous error, 20, 2. What is that? The drawing I need to generate the dtm from, and then slope, etc, is a dwg file. When I import as 3d only, I can use the flyover tool and see the contours and site in 3d. the 2 & 3d import does not let me do that. When importing as 3-d, it will generate one pyramid when I have it run the site model. It appears that it will not read the whole file, which is a fairly large site (185 acres in the mountains at 2' contours). I have a dual processor g-4 mac, and am using system 10.2.6, and have landmark 10.5. I had the same problems in the previous version of the landmark 10 program. Any insights are appreciated. Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted September 16, 2003 Vectorworks, Inc Employee Share Posted September 16, 2003 You could try using the "Filter 3D Polygons" command under the DTM Processor submenu. This eliminates excessive points in your 3D data. Quote Link to comment
