  • 4
Tom Klaber
Publish PDF Page Order by Sheet Order
It is kind of crazy that the publish command does not respect the sheet page order.  It is somewhat time-consuming to have to reorder the PDF pages everytime we want to export the sheets - especially since they are ordered correctly by Sheet Order.  That sheet order should be available to sort by in the Publish Command (if not the default).
2 answers to this question
The lack of relationship between the Publish dialog and the realities of Sheet Layers is a bit surprising. As you say, it should recognize the order. It should also recognize when sheets are renumbered or renamed too. It is easily confused.
Kevin
I am also dealing with re-arranging dozens of sheets.
Vectorworks team, can we add another column that will only populate for sheet layers that matches the # column in the Sheet Layers image?
As I always want to export my PDF's by sheet layer arrangement I already have.
