Text causing severe delay
Gareth Nixon
Hi,
I'm updated VW2018 to the current update, and also updated my Mac to OS Mojave.
I then opened up to work on my Vectorworks drawings, but when I try to enter text on the drawing it delays by so long I have to force quit.
Does anyone know of a solution?
MacBook Pro (15-inch, 2017)
2,9 GHz Intel Core i7
6 GB 2133 MHz LPDDR3
Kind Regards
Gareth
7 answers to this question
On 10/23/2018 at 2:37 PM, Gareth Nixon said:
Hi,
Kind Regards
Gareth
I have the same problem, almost identical hardware specs, my laptop became unusable, Any solutions?
Hi Oz,
I had to take it to the apple shop and explain the problem. they deleted Mojave, and replaced it with High Sierra.
Then I had to reinstall VW.
I suggest you back up everything and do the same, took about 6 hours in total.
I was told VW will be dealing with the issue in 2019, then will provide a patch for 2018 in March time.
Hop this helps
Good luck
Regards
Gareth
