High Detail with Hidden Wall Components
Tom Klaber
There used to be a checkbox to hide details and wall components in viewports.  This is now gone in favor of the detail level check box.  Disaster.  We use components in all types as a check on our own design, but do not ever want them going out in our drawings because they are not clean enough.  We are though, using the new detail level for our Symbols, and enjoying that very much - but for our plan blow ups - we are forced into showing wall components if we want to see the high-level detail version of our symbols.
I want the separate checkbox to hide wall components back.
5 answers to this question
Hi Tom,
Have you tried turning off the component classes in the viewport?
Another trick you can do is to leave the component classes visible but override their fills to None and their Pens to Solid with a zero line thickness. This will effectively hide them in the viewport but display then when you edit design layer through the viewport.
Thanks, Matt,
I can not turn them off or hide them as then I will not see the wall at all.  We need the wall to be colored or hatched per our key to distinguish rated walls, new walls, and existing walls.  Unfortunately, the components of these walls are shared, meaning I can not override the as there is no way to do that so they show up white in existing, gray in a new interior, and hatched in rated.
We are in a real pickle.
I think the only option is to set our symbols so that the low detail is actually high detail and just take the hit in the 1/4" plans.
