We migrated one of our projects to v.2019, but after running into a number of bugs, have backsaved it to v2018 as it is more stable.
The file, however, now appears to be corrupted.
In 2D, everything looks OK, but in 3D, the walls vanish, reappear, or display distorted depending upon which direction the model is viewed from (and none of them are actually correct)
Is there a tech I can send the file to - to determine if there is an easy fix. I could try copying all of the data into a new file, but the likelihood is that the problem is in the data and wouldn't go away.
Here's some screen shots of the behavior. The first one shows all 3D info hidden, except when your cursor runs over it a ghost appears. The second shows some kind of weird parallel universe where x-ray vision has been implemented (partially)...
Taproot
0 answers to this question
