Oliver Hauser
Title Block Manager crashes VW2019 Sp1
@Nikolay Zhelyazkov
Just did a little experiment. I moved the vwx file from my project folder which is stored on Google drive file stream to my desktop. I re-opened the file and tried to edit the title block in the same manner and it worked, no crashing.
Has this got to do with the folder hierarchy?
@Oliver Hauser
 - Yes. As of SP-1, it is good to have your active vwx file in a folder hierarchy with depth at least 4-5, that has only this file in it and no additional files and folders.
I am also having this problem. Even in a file that worked fine up until version 4 and now on my version 5 export I get spinning beachball when I try to go to title block manager to change the version number and the application. I have a deadline so I will go and manually put filled text blocks over where I should be able to change info through the title block manager until this issue gets solved.
I am on OSX 10.13.9 with the same crash. Titleblock manager simply crashes VW2019.
Tx for the workaround, , it does work so I can at least update the title blocks. Please fix this asap.
Cheers Francois
@Nikolay Zhelyazkov
Looking at the crashs, we could not find that VWX had crashed, but that CineRender did...
She will try to re-create this crash after the lessons... 🙂
So far we have this:
Beschrijving
Pad naar toepassing met fout:             C:\Windows\System32\DriverStore\FileRepository\nvlt.inf_amd64_b2022deee1f104cf\Display.NvContainer\NVDisplay.Container.exe
Probleem met handtekening
Naam van probleemgebeurtenis:      APPCRASH
Naam van de toepassing:       NVDisplay.Container.exe
Versie van toepassing:            1.15.2586.5913
Tijdstempel van toepassing: 5c75252f
Naam van foutmodule:           combase.dll
Versie van foutmodule:          10.0.18362.693
Tijdstempel van foutmodule:             1fabb0ef
Uitzonderingscode:    c00000fd
Uitzonderingsmarge:  0000000000043443
Versie van besturingssysteem:           10.0.18363.2.0.0.768.101
Landinstelling-id:         1043
Aanvullende informatie 1:     a625
Aanvullende informatie 2:     a62514fcf816511cba42b9c716df4c74
Aanvullende informatie 3:     a6ad
Aanvullende informatie 4:     a6ad64229730ee9d403e8cdb1b6ef9c9
Extra informatie over het probleem
Bucket-id:        273ca8313df8ae632a39b432d8c266d2 (1889739649136617170)
Thanks @Eli van Hooff,
If it crashes again look for a crash log file following the instructions from below.
On 10/17/2018 at 5:51 PM, Nikolay Zhelyazkov said:
You are working on Windows, right?
If so, open your VW user folder at "<user name>\AppData\Roaming\Nemetschek\Vectorworks\2019\" and look for a .dmp file that was created when your VW crashed when opening TBManager.
17 minutes ago, Eli van Hooff said:
@Nikolay Zhelyazkov Ah sorry... Just forwarded what I got from my student...
Here by the right version: VWCrashDump.zip
Seems like there is something wrong with this file, still cannot open it, sorry. Could you give me a test file and steps to reproduce the crash if possible?
Thanks.
