Sade
Lineweight
I'm trying to draw this site I have been given at uni however, I want to change the line thickness(or colour), so that you can tell the difference between the buildings that are at the back and at the front of the site. What is the easiest way to do this?
Select the object, and go to the Attributes Palette to change color, lineweight, fill, etc.  Make sure an object is selected, otherwise changes made in the Attributes palette will change your defaults for new objects you create.
The above assumes you are talking about 2d objects.  If you are working in 3d and displaying the masses in OpenGL rendering mode, you will not necessarily see the lines at the edges of an object.
Edited by P Retondo
