Wall id tag disassociating if copied or moved
SNOJNKY
I've gone through a ton of work to create styled walls for a complex renovation.  After tagging an area of styled walls with the ID TAG, all is well. . . .until I move the tag, copy the area to the next floor up, or try to create a symbol of the tagged walls to copy to another area of the building.  Tags look normal but do not update when the style walled is replaced with another styled wall.  My walls are color coded, so I can tell immediately if a 1 hr tag is on a non-rated wall -- and they're ALL messed up!
Assuming I can get this resolved ASAP, should the tags in the bathroom of a hotel, for example, be located on the screen plane or the "symbol"?  I can't seem to edit them if I change them to "symbol", but I'm more concerned about having to tag every single wall and never moving the tag to make it stay "smart".
Any help with wall id tags would be appreciated.
Thank you!
-Carol
0 answers to this question
There have been no answers to this question yet
