tismacfan2 Posted October 11, 2018 Share Posted October 11, 2018 Hello In Belgian we have an own window tool, but there are problems with tis tool when I used it as a cornerwindow, specially when it is een inside corner See fig 1 & 2. In 2d is the presentation OK, but when I switch to a 3d view, is the wall disappeared en I only see the window. When I in the 3d view delete the window than I see te wall back. If I use the American version of the window is everything ok but is there a possibility to set the window behind the exterior wall as in fig 3 What should be the settings if I want this Thanks for the support Pascal Quote Link to comment
