Palle
Spotlight Tool Set does not show
I'm working in Designer, and when switching to the Spotlight workspace, the tool set palette is not visible. When I turn it on, it shows as an empty gray rectangle. I can move it around, but not access any tools or dock it. When I switch to other workspaces, I do not have the same problem - the tool sets are there, and working.
Is this something I can fix myself?
Best,
Palle
4 answers to this question
First recommendation would be to close Vectorworks completely, then backup and reset your Vectorworks preferences, since i'm not able to replicate this here:
After doing this, restart, then go to the default Spotlight workspace and see if you see the palette. If not, contact tech@vectorworks.net directly, they will likely need the last 6 of your serial number as well as that SPX file.
