Steve Nield Posted October 7, 2018 Share Posted October 7, 2018 (edited) I have seen posts on this topic but nothing that fixes it. At the top of the attached image is the label legend i built for a City Colour, . At he bottom of the attached image you can see that the Universe and address fields are swapped over and the text moves to the other side of the lamp when i rotate the symbol. I have been going back on forth on this one and i am sure there is an easy fix but its late and i need to extra brain power please. Edited October 7, 2018 by Steve Nield Quote Link to comment
JBenghiat Posted October 10, 2018 Share Posted October 10, 2018 Check the alignments of your text blocks. This may be counter-intuitive, but in order for two blocks to stay in alignment for all angles (unless you turn adjust flipped text off and have upside down text) is to set the alignment to Center/Center. Spotlight identifies the label text blocks in the legends by an attached hidden record, so the text can be anything you want, for example X- and XXX, which will help you with initial alignment. 1 Quote Link to comment
Steve Nield Posted October 11, 2018 Author Share Posted October 11, 2018 Thank you, yes that makes sense. I have the universe field set to right justify and the address field set to left justify solo they appear connected. Quote Link to comment
