ionw Posted December 14, 2004 Share Posted December 14, 2004 I have noticed that in VW 11.01 and VW 10.5.1 that you cannot use the angular dimension tool to dimension between objects that are on other layers. Is there a reason for this? it looks like all the other dimension tools work across layers. not a huge issue, we only use it occasionally so drawing a couple extra lines to get the dimension isn't a problem, I am just curious. thanks ion Quote Link to comment
canarch Posted January 20, 2005 Share Posted January 20, 2005 i've also notice that you cannot use the angle dimension between a line and a line that is contained within a group. but as you said i too do not use this tool much so drawing a few extra lines does not take up too much time, but it does appear to be a major flaw. thanks Alistair Quote Link to comment
Vectorworks, Inc Employee Bruce Ferguson Posted January 21, 2005 Vectorworks, Inc Employee Share Posted January 21, 2005 Ion, You can use the angular dimension tool to dimension between objects that are on other layers if you have your layer options set to show/snap/modify others. Quote Link to comment
ionw Posted January 21, 2005 Author Share Posted January 21, 2005 Thanks Bruce, Good info to know. ion Quote Link to comment
