I've always made my own custom tools to reduce clicks on commonly used objects. Like my leader line tool, I have it set for my text class, line weight 5, the line end marker I want, & unconstrained. It has always worked in many previous versions of VW. But the Break line, in the past few versions I can not set it to drawl the leader line at line weight 1 and to be on a certain class. I do everything the same as I do other custom tools & I can see the line weight & class in the custom tool script when trying to edit it from the Resource Browser. There is nothing to edit because it is all listed correct, but VW does not use the listed line weight nor class. I have made other custom tools with no problem, it is just this tool so far that will not work right. Any suggestions?
Dubman
Thanks
0 answers to this question
