rowbear97 53 Posted October 1, 2018 I don't know if this a 2019 issue or I haven't been paying attention but there is something clearly wrong with text sizes and labels with the planting tool. As you can see in the attached images I have plant tags that show as 10 pt on the design layer but when one goes to the sheet layer the text shows as larger than that. I only just now noticed it because the drawing label tool is set to 10 pt and it is scaled correctly. I've tried different fonts as well just to verify and each time the plant tag is bigger than it should be. Any help on resolving this will be greatly appreciated! Quote Share this post Link to post
