JulieK Posted September 27, 2018 Share Posted September 27, 2018 I'd like to create windows that have trim on the exterior but use drywall returns instead of trim on the inside. If I create a window that way, there's a gap between the window frame and the wall when you look at the window from inside the house. Is there a way to fill in that space so it looks like a seamless drywall return? Quote Link to comment
bc Posted September 27, 2018 Share Posted September 27, 2018 Could it be that you have a shim gap specified and that is showing. See what happens when you uncheck the shim gap box in the Object Info Palette? Quote Link to comment
Diego-Resuelvectorworks Posted September 27, 2018 Share Posted September 27, 2018 If you use a wall with components, the best way to do it would be use the Interior Components feature in the Window Settings Quote Link to comment
JulieK Posted September 27, 2018 Author Share Posted September 27, 2018 Thanks for the suggestions. I tried both, but they didn't work. However, in the process I discovered that I could use the "Edit 3D Wall Hole Component" command on the window unit to do what I want. Quote Link to comment
