gfebres@gfarch.ca Posted September 21, 2018 Share Posted September 21, 2018 I recently upgraded to VW 2019, and some basic shortcuts do not work, particularly the ones to select drawing tools, like a line. If I use the shortcut (2), it changes the view to an elevation view. I verified the workspace and the shortcuts are as they should be, but when used VW goes to different views instead of selecting the tool I want. Please help Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted September 21, 2018 Vectorworks, Inc Employee Share Posted September 21, 2018 Hi Can I assume you have an extended keyboard with a number pad? If so, click on the cog icon to the top right of the drawing area and choose Allow numeric keypad entry for Instant Data Bar Activation. This should stop the view changes. Quote Link to comment
Andy Broomell Posted September 21, 2018 Share Posted September 21, 2018 Another thought.... 2 is line and Cmd+2 (or Ctrl+2) is front. I wonder if one of the keys on your keyboard is being pressed down inadvertently? I once had a similar issue, which was fixed when I realized my external keyboard was underneath some crap on my desk and keys were being pushed, haha. Quote Link to comment
mar schrammeyer Posted September 26, 2018 Share Posted September 26, 2018 I had a similar problem with text (1) and call out (option 1) but this was only in one workspace advice from OzCad (if you edit the workspace and remove then add back these shortcuts, it will work again. Sorry for the inconvenience.) 1 Quote Link to comment
gfebres@gfarch.ca Posted September 26, 2018 Author Share Posted September 26, 2018 Tested every thing suggested: As Rob indicated, using the number keys above the letters instead of the keypad works, but I normally used the key pad for short cuts in VW 2018. Just tested shortcuts running VW 2018 and they all work, using the keypad, even if "do not allow keypad entry for instant data bar activation" is selected. Tried selecting "allow keypad entry for instant data bar activation" as Tamsin indicated, but it made no difference VW 2019, shortcuts do not work from keypad, just changes views. Also tested in VW 2019 editing the workspace, setting the "/" (the one on the keypad) to select the line tool and it works, even if the data bar and edit group options has "do not allow numeric keypad entry..." selected or unselected. Quote Link to comment
zoomer Posted September 26, 2018 Share Posted September 26, 2018 I have problems (at least in Mojave) that Double "X" doesn't deselect anymore. Quote Link to comment
gfebres@gfarch.ca Posted September 26, 2018 Author Share Posted September 26, 2018 Thanks Mar Schrammeyer, removing the current shortcut character, exiting, going in again and replacing the character with the original worked, a bit of work, doing it for each one that did not work, but solved the problem. 1 Quote Link to comment
Vectorworks, Inc Employee Payne Chang Posted September 26, 2018 Vectorworks, Inc Employee Share Posted September 26, 2018 Hello gfebres, Thank you for your posts and updates. We would like to fix this issue in future releases. I am wondering whether you migrated your 2018 workspace file or edited your 2019 workspace file before the shortcut issue. If you did use Migration Manager, I am wondering if you can send your 2018 workspace file to me so I can investigate. Thanks, Payne Chang (pchang@vectorworks.net) Vectorworks Software Engineer Quote Link to comment
gfebres@gfarch.ca Posted September 26, 2018 Author Share Posted September 26, 2018 There was a problem during the migration, it could not migrate my workspace, it indicated that. So I did not start VW 2019 with my work space. The problem started with the workspace that came with VW 2019. I created a new workspace and modified it while trying to fix the issue. Quote Link to comment
gfebres@gfarch.ca Posted September 26, 2018 Author Share Posted September 26, 2018 Here is my VW2018 Workspace file Architect Gabriel.vww Quote Link to comment
Vectorworks, Inc Employee Payne Chang Posted September 26, 2018 Vectorworks, Inc Employee Share Posted September 26, 2018 Thanks a lot for providing your workspace file. I will investigate the issue and make improvements in future releases. Quote Link to comment
GeeRoy3 Posted April 1, 2019 Share Posted April 1, 2019 Having same issue with 2019. New to VW. Began tutorials for 2018, numeric keypad worked A-OK. Upgraded to 2019 last week, no worky. Quote Link to comment
allannthuee92 Posted June 17, 2019 Share Posted June 17, 2019 After latest upgrade the boomerang mode doesn't stay active by only staying on for a split second (and I'm not even opening ANY file), both on my Macbook Air keyboard and the Apple Keyboard (no extra numeric pad, the short version). It wasn't like this before the VW upgrade about one month ago, and I'm using iOS Mojave 10.14.5 (latest one too). Quote Link to comment
The Bloosmbury Gardener Posted November 14, 2020 Share Posted November 14, 2020 Hi, I have a similar issue here. My offset shortcut (Shift + hyphen) doesn't work (there are others that don't work either but I don't use them that much). My VW was 2018 and updated for 2019. Any ideas please? Quote Link to comment
