Paul S. Morrill
Best way to Create a Large billowy Sail?
So I need to create a Large Sail of a sheer material for an entertainment project.  it need to be billowy and does not hang flat.
any thoughts on how to go about this.   Thinking a lofted surface of some sort.  Thoughts???
TIA
-Paul
Yes, I would loft this in VW. I would draw a squiggly profile for the bottom, duplicate and modify that a few times for the internal profiles (you'll need to experiment a bit. Off set these left or right to create that swag feel. And then one more for the top that is flatter/thinner for the top hem/pleats. Better to modify the original base profile instead of drawing new ones as you are sure to keep the same number of points (this is important and will give you better lofts).
^ this is a good way to approach this. Lofting gives you good control over the size and shape.
Kevin
