Chickpea Posted November 13, 2018 Share Posted November 13, 2018 I'm new to the stair tool. I've been trying to use it in landmark for external steps. If the tool can only offer basic functionality in terms of two elevations and calculating riser heights and tread depths, please can you add a feature that allows you to calculate a fall across each tread. If it could be all singing and dancing, it would be great if you could specify tread make up a bit like a slab, and risers as a wall, so you can put a section through and get the construction... 2 Quote Link to comment
hmart Posted November 20, 2018 Share Posted November 20, 2018 Stairs should allow you to pick from all designated levels, not just "[Story Above]" Could be separate Selections Top Bound: Select Story: Select Level: Top Offset: On mult-level or split level structures, "Story Above" can be quite limiting. 3 Quote Link to comment
Diego - Resuelvector Posted November 23, 2018 Share Posted November 23, 2018 Just to add someting to the pot... This kind flexibility is what we need. 4 Quote Link to comment
taoist Posted November 24, 2018 Share Posted November 24, 2018 Here is a link to 3rd party stair parts using Vectorworks to create. Being a residential home designer/estimator, these parts are just what the doctor ordered. We should already have these. Current limitations of what is given us for options is conceptual at best. Should have Custom Tab for adding or selecting railing profiles. https://www.newenglandstairworks.com/cad-models/ taoist 1 Quote Link to comment
lupin Posted February 19, 2019 Share Posted February 19, 2019 There was a lot to read through in this thread! Did anyone ask for the tool to allow for a 1 tread stair? This would be great for split level rooms, and a single tread between or at the end of a landing. Quote Link to comment
Patrick Fritsch Posted March 12, 2019 Share Posted March 12, 2019 Add to your list that it does not makes sense to have the control handles for up/down text on same floor, should be controllable on each respective floor...it's like a guessing game position the upper floors text currently. see attached. 1 Quote Link to comment
Art V Posted March 12, 2019 Share Posted March 12, 2019 On 9/14/2018 at 9:40 PM, zoomer said: And of course things like Fire Stairs or Industrial Stairs on Oil Platforms that span more than one Story, as a single controlled Object would be nice. This is one of the things I'm missing the most, especially because these structures can have unequal level spacing that needs to be accomodated for. The old custom stair tool did reasonable with eqally spaced levels but none of the stair tools so far can handle unequal level spacing, plus that after some height it just breaks down. E.g. some structures are 40m high or have space restrictions (e.g steep stair needed) and have/need a single stair with multiple landings etc. which is currently really cumbersome to get it right within the requirements that are specified. (i.e. maximum number of treads, maximum rise, minimum/maximum angle etc., levels etc.) It would be really nice if I could define the parameters (run/rise, levels, min/max numbers for treads etc.) and then specify the starting, intermediate and ending levels and the stair tool would then calculate the optimal stair (e.g. after every 12 treads but no less than 5 treads for any flight there should be a landing, or after every x meters up in height there should be a landing etc. to get a more uniform sequence of flights instead of having to go by trial and error and then redo the whole mess when levels change.) 2 Quote Link to comment
Art V Posted March 12, 2019 Share Posted March 12, 2019 (edited) On 11/23/2018 at 1:15 AM, Diego-Resuelvectorworks said: Just to add someting to the pot... This kind flexibility is what we need. I totally agree with this, if it can handle multiple unequal levels as well then this would solve quite a few of my issues with the stair tool. Edited March 12, 2019 by Art V 2 Quote Link to comment
herbieherb Posted March 13, 2019 Share Posted March 13, 2019 We also need a way to manipulate the walking line. This is the walking line in Switzerland. It's very different from what the current staircase tool does. It would also be very nice to have the sound insulation inserts and the plastered bottom view as a separate geometry inside the stair-tool. This is the level of detail, we draw our stairs: Quote Link to comment
zoomer Posted March 13, 2019 Share Posted March 13, 2019 I wonder more why you have Solid Appearance of the Flight in Clip View and I have not ? (Or is that a real Section in Edit Mode ?) Quote Link to comment
herbieherb Posted March 13, 2019 Share Posted March 13, 2019 (edited) It's no Clip-View. It's actually just a normal OpenGL view of the stair i copied into a new file without walls and floors. It's modeled without the stair tool. The red object around the stair is the sound insulation, not the clipped sides of clip-view. Edited March 13, 2019 by herbieherb 1 Quote Link to comment
zoomer Posted March 13, 2019 Share Posted March 13, 2019 42 minutes ago, herbieherb said: It's modeled without the stair tool. Got it 🙂 I saw the first Isometric, and the lowest sound dampening looked for me like it would be the most front part, exceeding the clip box, because being selected 🙂 1 Quote Link to comment
Brian H Posted June 12, 2019 Share Posted June 12, 2019 This is a great list. When can we expect to see any improvements with the stair tool? This tool is the most frustrating feature in VW, no doubt. Quote Link to comment
line-weight Posted June 12, 2019 Share Posted June 12, 2019 1 hour ago, Brian H said: This is a great list. When can we expect to see any improvements with the stair tool? This tool is the most frustrating feature in VW, no doubt. Around 2025 perhaps. 1 4 Quote Link to comment
TomKen Posted June 18, 2019 Share Posted June 18, 2019 Stairs can be very complex items, I would be happy even if I model my stairs then tell Vectorworks that this is a stair object and have it show up on the first floor and second floor the same way the stair tool does it now, and have control over how it displays on the first floor and second floor. 1 Quote Link to comment
zeno Posted January 26, 2020 Share Posted January 26, 2020 Remember this thread, guys. We already need another stair tool... hope to hear some news about this very soon.. 4 Quote Link to comment
Raja Posted November 14, 2023 Share Posted November 14, 2023 (edited) Great posts, interesting to see what we are struggling with. This may have already been covered, but one thing that consistently drives me crazy (I have not yet upgraded to 2024, maybe it's fixed??) is the inability to dash the handrails with the rest of the stair. So the stair above or below the cut line basically should always be shown as dashed, yet this is never a default setting, and then when you show the dashed stair below or above cut line, the railing is solid instead of dashed. Making the handrail tool utterly useless. The stair tool has so much promise but at the same time it has both too many and not enough features... Edited November 14, 2023 by Raja doubled comment 2 Quote Link to comment
