Sustainable Posted November 24, 2004 Share Posted November 24, 2004 How would I rotate an entire drwing .32 degrees? Quote Link to comment
jfmarch Posted November 24, 2004 Share Posted November 24, 2004 if you are talking about rotating all objects in a file, use the rotate tool. i don't think, nor no why, you can rotate a sheet view. you might need to clarify your question. Quote Link to comment
jan15 Posted November 24, 2004 Share Posted November 24, 2004 You have to have all layers and classes used in the drawing visible, and Layer Options and Class Options both have to be set to "Show/Snap/Modify Others", and then you select everything, either with the Select tool or the Select All command. With the Rotate command, you specify the angle in a dialog box, and everything rotates around the centroid. With the Rotate tool, you click at the fulcrum, then at the start and end points of the arc of rotation. You can enter the angle in the Data Display bar, or you can use a pair of lines at the desired angle to each other, snapping first to one and then to the other. Quote Link to comment
klaus Posted November 25, 2004 Share Posted November 25, 2004 I agree with jan15 ..... but also make sure you set the angles precision you want in the 'units' dialogue box before entering the angle in the Data Display bar using the Rotate tool Quote Link to comment
