naomi3 Posted September 14, 2018 Share Posted September 14, 2018 Hi everyone. I have been trying to add or subtract from various solids and extrusions. I'm finding that depending on the type of object they will not union or subtract. If for example; I want to union (add solid) a generic solid or extrusion to a solid addition or solid subtraction, the Model> Add Solids / Subtract Solids... will be greyed out and I cannot run the command. I have a 3D AutoCAD background, so in my previous experience you could union most types of solids fairly easily in AutoCAD. This either is not the case in VWs or I just don't know the correct procedure. Can you only run certain boolean commands on certain types of solids / extrusions?? This is quite frustrating as I am new to VWs & know I would not have this issue in AutoCAD 3D. Can anyone shed some light on this? Thanks, Naomi. Quote Link to comment
zoomer Posted September 14, 2018 Share Posted September 14, 2018 2 hours ago, naomi3 said: I'm finding that depending on the type of object they will not union or subtract. If for example; I want to union (add solid) a generic solid or extrusion to a solid addition or solid subtraction, the Model> Add Solids / Subtract Solids... will be greyed out and I cannot run the command. I have not seen limitations. One thing I remember when I started with VW is that I was very frustrated when Solid Add/Substract where greyed, that they have to be on the same Layer ! If you came from ACAD, ACAD Layers are Classes in VW. And VW Layers are something non existing in ACAD. Quote Link to comment
