Vision 2019 SP1
Vision 2019 SP1 has been released. You can find the Mac and Windows downloads below:
Mac   -   Windows
Summary of fixes:
  • Position of MVR imports is fixed
  • Quitting Vision in Fullscreen mode caused DMX Recorder to be tabbed on macOS on the next launch. On PC it could sometimes make the menu unreachable
  • Fullscreen now exits to previous window position
  • DMX Recorder will always be brought to front
  • Trial numbers always load sponza demo file on launch
  • If Vision does not have a previous window position at launch, it will now start maximized
  • Patch can now be changed in Prop Win
  • Patch no longer exhibits off-by-one errors
  • Patch Window has been hooked into the undo table such that after OK is clicked, undo/redo will undo/redo the patch changes one at a time
  • Deleting should no longer cause a crash with large files and multipart fixtures
For more information: https://www.vectorworks.net/en/vision
  • Like 2
HI, Can you help me,
I have just bought Vision 2019 and I am running on a Mac
OS 10.13.6
the program runs fine till I send it some data from the desk and then crashes.
I have also tried loading Vision on to a windows PC and it will not even open?
I have downloaded the latest version including SP1
Any ideas?
Thanks
Rich
  • 2 months later...
Hi, I upgraded Vectorworks to 2019 SP2 and then Vision 2019 on my Mac.
Vision launches but crashes whenever I select a instrument in the Scene Graph.
I moved the old version of Vision to trash and the problem persists. I then did the same to the 2019 version and tried a reinstall. Still gives me the error.
Any help appreciated.
Tom
9 hours ago, tddesigner said:
Hi, I'm looking for where I can download the Windows version of Spotlight 2019 and Vision 2019. I have them in MacOS where I did the update from 2018. Thanks.
For Vision:
http://release.vectorworks.net/latest/Vision/2019-NNA-eng-win
For Vectorworks, message me privately with the last 6 of your serial number and i can make sure to get you the correct installer.
  • JuanP unpinned this topic
