import python module from a script in current file
twk
I suppose that it is possible, however "import" uses the current sys.path which might not what you want
The possibilities I see are:
- modify sys.path to have the path you need
- use one of the functions of https://docs.python.org/3.5/library/runpy.html (if it suits you)
- use one of the functions of https://docs.python.org/3.5/library/importlib.html
As I have never used any of them from the Python provided with VW, I am not sure what the best solution might be.
  • 2 weeks later...
  • 1 year later...
In Vectorscript the following will get you a handle to a script object in the current file. I have not figured out how to get the text out of the object to be able to run it. I don't think there is a way to run Vectorscript, but PythonExecute should work IF you can find a way to get the text out of the handle to the object.
Procedure Test;
Var    NumItems, ListID:LongInt;
    H1:Handle;
    S1:DynArray of Char;
Begin
    ListId:=BuildResourceList2(49,0,'',NumItems,False);
    AlrtDialog(Concat(ListID,'  -  ',NumItems));
    H1:=GetResourceFromList(ListID,1);
    AlrtDialog(GetName(H1));
End;
Run(Test);
Procedure Test;
	H1:Handle;
Begin
End;
Run(Test);
  • Like 2
  • 9 months later...
I would like to do the same. I'm testing the function vs.GetScriptResource('Nameofmyscript)[1].
If I run a Script like this:
text = str(vs.GetScriptResource('Ebenenauswahl')[1])
vs.CreateText(text)
I get all the text of my script. But if I want to use a name out of 'Ebenenauswahl' it says "name '...' is not defined.
What am I missing?
