twk
import python module from a script in current file
As the title suggests, is this possible? If so, what is the syntax?
I suppose that it is possible, however "import" uses the current sys.path which might not what you want
The possibilities I see are:
- modify sys.path to have the path you need
- use one of the functions of https://docs.python.org/3.5/library/runpy.html (if it suits you)
- use one of the functions of https://docs.python.org/3.5/library/importlib.html
As I have never used any of them from the Python provided with VW, I am not sure what the best solution might be.
No I meant, I'm trying to import a module from a script inside the VWX file.
I had the same problem
You have to add the path file into the "Script Options..." dialog
Is that what you meant twk?
971469283_Schermata2020-01-17alle23_39_54.thumb.png.9399d17e41a56781774d0a863e03f585.png
I was wanting to call a function from another script that is within the document resources. Not on a file somewhere else on the computer.
cheers
In Vectorscript the following will get you a handle to a script object in the current file. I have not figured out how to get the text out of the object to be able to run it. I don't think there is a way to run Vectorscript, but PythonExecute should work IF you can find a way to get the text out of the handle to the object.
Procedure Test;
Var    NumItems, ListID:LongInt;
    H1:Handle;
    S1:DynArray of Char;
Begin
    ListId:=BuildResourceList2(49,0,'',NumItems,False);
    AlrtDialog(Concat(ListID,'  -  ',NumItems));
    H1:=GetResourceFromList(ListID,1);
    AlrtDialog(GetName(H1));
End;
Run(Test);
Procedure Test;
	H1:Handle;
Begin
End;
Run(Test);
