building irregular exhaust
Lofting eith rail has shortcommings. I think that lofting with no rail should do the job. If it doesn't look quite right, you can try redoing the loft by using the 'create contours tool' ? and edit/change the contours, that are off.
Or you can try doing most of the shape as one big nurbs surface: Create the basic nurbs surface in a very simplified form with as few vertices as possible, then move, edit and add vertices until it looks right. I have done the hull of a sailing boat with just 12 vertices in all.
