Swatz
I just created a speaker and speaker bumper...
At-present, you can't use existing Symbol geometry.  You'll need to grab dimensions from what you've created, input the values into the appropriate parameter fields in the Speaker Array "Configure Array" dialog, and save your settings to the library.  The tool(s) will then generate simplified versions of your models.
...and...knowing you'll ask...yes, allowing this functionality IS on The List...
That's interesting because there is an option to import. Which I tried to do, but I guess you have to have a certain record format attached. I also tried using the same record format in the Bumpers file, but no luck there either. I just used the symbols as they are and made my line array.
Thanks for the reply.
"Import" causes the tools to create geometry based on data grabbed from either "__ATS-SpkrModData" or "__ATS-BumpModData" - which are records attached to appropriate Symbols.
