Swatz Posted September 6, 2018 Share Posted September 6, 2018 Now the question is, how do I use my custom bumper in the speaker array tool? RCF HDL-30A.vwx Quote Link to comment
C. Andrew Dunning Posted September 6, 2018 Share Posted September 6, 2018 At-present, you can't use existing Symbol geometry. You'll need to grab dimensions from what you've created, input the values into the appropriate parameter fields in the Speaker Array "Configure Array" dialog, and save your settings to the library. The tool(s) will then generate simplified versions of your models. ...and...knowing you'll ask...yes, allowing this functionality IS on The List... Quote Link to comment
Swatz Posted September 6, 2018 Author Share Posted September 6, 2018 That's interesting because there is an option to import. Which I tried to do, but I guess you have to have a certain record format attached. I also tried using the same record format in the Bumpers file, but no luck there either. I just used the symbols as they are and made my line array. Thanks for the reply. Quote Link to comment
C. Andrew Dunning Posted September 6, 2018 Share Posted September 6, 2018 "Import" causes the tools to create geometry based on data grabbed from either "__ATS-SpkrModData" or "__ATS-BumpModData" - which are records attached to appropriate Symbols. Quote Link to comment
