Changing stage colour
sjordan_
Hi all,
I am fairly new to Vectorworks Spotlight (3D) as I have only used it for floor plans previously.
I understand how to create a stage but once I have created it, it will not give me the option to change the colour of the stand in the object info panel.
Also changing the class colour in attributes doesn't make a difference either.
Please help?!
Sam
To apply custom Textures:  In the "3D Options" dialog, choose "Custom Texture" for the appropriate piece.  The Texture chooser pop-up will be enabled.  Pick the Texture you want.
To edit an existing Texture definition:  In the Resource Manager, make sure "All Resources" or "Renderworks Textures" are visible.  Right-click on the one you want to change, and choose "Edit."  Then make changes to the desired shader, in this case, "Color."  When finished, click "OK" and you should see the effects of the changes you made.
  • Love 1
