justinekwood
Saved As file won't let me amend existing elements after the first session
I created a garden design and am now tweaking amends.  Originally I thought the problem was with layer and class visibilities but it is not.  When I visit the layer with most of the concept design ion I can see it in grey outline but I can't select or amend any of it.  It is appearing in the sheet layer that I created to print the design.  Some of the objects (a table and chairs) are showing but the majority of the objects - hardscaping planting etc isn't.  I attach a screen grab of the design layer and then the sheet layer to illustrate what I mean.  View, design layers and classes are on show snap others and apart from this I can't work out what I have switched on or off to make this happen.  When I save as the original file I can select and amend the elements.  It is only after I have finished working and I revisit the file to continue working that everything appears greyed out.  Is this a bug anyone knows about?  Because I am on the student version, I don't appear to get access to the newer versions of the software.
2 answers to this question
You are looking at either grayed layers (most likely) or classes.  Check your navigation palette:  is your general class setting (at the top) Show/Modify Others (it should be)?  Are any individual classes set to gray that shouldn't?  In the general layer setting, you should see either Show/Snap Others or Show/Modify Others.  Are any of your individual layers gray that shouldn't be?
BTW, when you take a screen shot like this it would be helpful if you included the navigation palette.  Also, it is sometimes important to know the VW version you are using.
Thanks for this.  One class was greyed out and it solved the problem.  thanks
Thanks for the hint on the screengrab
Edited by justinekwood
