LeeClarke Posted August 25, 2018 Share Posted August 25, 2018 Currently running Vectorworks 2014. I am finding that when I export a worksheet into PDF any lines that are at an angle are appearing grey in the PDF. Any ideas to correct this please hannington hall Doors.pdf Quote Link to comment
michaelk Posted August 25, 2018 Share Posted August 25, 2018 I see the grey lines int the section, but I don't see a worksheet. Are you creating the pdf from VW or from Mac OS? If you're using a Mac, using the Mac OS PDF engine sometimes works better. Or at least differently. 🙂 Quote Link to comment
LeeClarke Posted August 25, 2018 Author Share Posted August 25, 2018 Exporting from VW on pc version. Happening all the time but can't see what is causing it. Seems to be arcs curves and any line that is not on x or y axis Quote Link to comment
herbieherb Posted August 27, 2018 Share Posted August 27, 2018 The export is correct, when you zoom in, the lines are shown correctly. They are only shown in gray on the screen by the PDF viewer when you zoom out. If you print the PDF, they are also correct. 1 Quote Link to comment
