I usually use the "Roof Face" tool instead of "Create Roof" but I would really like to use "Create Roof" for a fully connected roof on this project. My biggest problem is that I have double lines at the edge of the roof. One inside at the "edge of roof"/bearing point and one at the edge of the overhang. The only way I can get the double lines to go away in 2d is to create a roof 12" larger than the edge of my walls with no overhang. Is there any other way to adjust this? I'd love to be able to keep the bearing part of the roof the same and then play around with the eave depths, but I can't have this double line situation showing up in my roof plan. The only other solution is to just make all of the faces individually.
JHAM
Hey all,
Am I overlooking some easy solution here?
Jena
1 answer to this question
