bc Posted August 21, 2018 Share Posted August 21, 2018 When I want to use the Incandescent Fixture Tool, the stem of the fixture in Wall Mode is too long (for me). Is there a way to alter the plan view of these objects? Or do I have to make my own symbols for each instance (and therefore lack the OIP editing)? Thanks bc Quote Link to comment
HHFurr Posted May 21, 2021 Share Posted May 21, 2021 Yes in VW 2021 but you lose PIO function. Right click & hold on the object then you get options select: Edit 2D Components Edit away. The big disfunction is you can't change a configuration label anymore. (really wished this worked better) So it really only works as a way to customize a single instance or type not holistically changing & customizing the way the PIO looks. Quote Link to comment
