nikolas 0 Posted August 16, 2018 Hello everybody, I would like to ask if it is possible to import from rhino to vectorworks, surfaces or polysurfaces and convert them to walls, floors, roofs? thnx Quote Share this post Link to post
0 JuanP 998 Posted August 16, 2018 Take a look at this guide: https://www.vectorworks.net/training/2018/getting-started-guides/transitioning-to-vectorworks/moving-from-rhino 1 Quote Share this post Link to post
0 nikolas 0 Posted August 17, 2018 Dear Juan, I check this guide that you attached but don't answer to my question. Could you please advice me about my quaries. Kind regards, Nikolaos Varlagkas Quote Share this post Link to post
0 rjtiedeman 27 Posted August 21, 2018 (edited) Export from RHINO as a parasolids (x_t) file or STEP file. See this link from RHINO home site. You might try others there are many options. I would start with the 2 I mentions. I have had good results with both. https://www.rhino3d.com/formats Edited August 21, 2018 by rjtiedeman Quote Share this post Link to post
0 Kevin McAllister 1,153 Posted August 21, 2018 10 hours ago, rjtiedeman said: Export from RHINO as a parasolids (x_t) file or STEP file. See this link from RHINO home site. You might try others there are many options. I would start with the 2 I mentions. I have had good results with both. https://www.rhino3d.com/formats Design series versions of VW have native Rhino import and export. On 8/16/2018 at 12:52 PM, nikolas said: surfaces or polysurfaces and convert them to walls, floors, roofs? I'm guessing this is the part of your question that isn't getting answered. There aren't conversion options for creating parametric objects in the VW Rhino import/export dialogs. Only a few import options recognize this type of conversion (Sketchup?). I don't think there are internal VW tools to do the conversion after the fact either. Most of the internal tools create parametric objects from 2d polylines/polygons not from 3d curves/surfaces/solids. Kevin Quote Share this post Link to post
0 nikolas 0 Posted August 21, 2018 Dear Kevin and rjtiedeman, thanks you a lot for your answers. What I'm thinking of, is to create a workflow between Rhino (modelling) to Vectorworks (architecture planning). More specific, if I create a freeform surface in Rhino could I converted it at Vectorworks on a wall with specific characteristics and fit to it doors, windows, etc? Nikolas Quote Share this post Link to post
0 Kevin McAllister 1,153 Posted August 21, 2018 7 minutes ago, nikolas said: What I'm thinking of, is to create a workflow between Rhino (modelling) to Vectorworks (architecture planning). More specific, if I create a freeform surface in Rhino could I converted it at Vectorworks on a wall with specific characteristics and fit to it doors, windows, etc? Hi Nikolas, I don't think this is possible. Parametric walls in VW are very geometric (eg. they don't lean and only simple curves are allowed). You could cut openings in your geometry manually and still use door and window objects. Kevin Quote Share this post Link to post
0 nikolas 0 Posted August 21, 2018 Dear Kevin, Thank you for the answer. Kind regards, Nikolaos Varlagkas Quote Share this post Link to post
0 rjtiedeman 27 Posted August 22, 2018 Nikolas, I rarely import objects into vectorworks. If I do it is as a reference for redrawing. Normally importing from other software introduces 3D anomalies in the file that will only cause issues later. But. Thats just me. Why load you project with potential issues. Bob Quote Share this post Link to post
Hello everybody,
thnx
