In the attached file I've got two renderworks viewports, looking at a simple cube and a site model. Both of those objects are in a class with a pink/purple texture, and sure enough they render correctly in the top viewport.
However in the bottom viewport, I've set that class to be over-ridden with another class which has a yellow-orange texture.
The cube takes on the new texture as expected but the site model doesn't (the side skirt does but not the 3d polygons on the surface).
In the settings for the site model the graphic properties for the 3d polygons are set as "site model class". Therefore they should be "pink class" which should be over-ridden by "orange class" in the bottom viewport but this doesn't happen. If I change that attribute setting from "site model class" to "pink class" the same happens.
line-weight
coverride.vwx
4 answers to this question
