Sam Jones
Has the Path changed, lengthened or shortened
In an event driven path object is there an event that flags that the path has changed, and whether it has lengthened or shortened?
TIA
Sam
Just the fact that you changed the object, it should call the regeneration code. To test whether the length has changed, you  could store the last value in a hidden parameter and then compare to the new length.
vsoStateGetExitGroup() will let you know if the user did a reshape or exited the path group.  You’ll have to use a hidden parameter for the length change.
Cool, I only need to know if the user has changed the path, not how it got changed.  But,
FUNCTION   vsoStateGetExitGroup( hObj:HANDLE;VAR outGrpType:LONGINT) :BOOLEAN ;
What is the "outGrpType", and True or False as a result of what?
Thanks so much.
