Export Worksheet > TXT File (Append and WriteLn)
Hi Everyone,
I Have a worksheet in Vectorworks, with the CMYK values and, the code/nome of product.
I need to convert this in .xml, like this below:
<D>0.000000,0.117647,0.156863,0.419608</D>
<N>SW 0001&#160; - Mulberry Silk</N>
I trying made this with this Script below:
But I have problem with separation after 0 (.), My export script doesn't put dot (.), Decimal point, after 0.
MY EXPORT PLUG IN:
000000,3584070,6858410,113725
R129Abóbora
I WANT IT TO BE LIKE THIS:
0.000000,0.3584070,0.6858410,0.113725
R129Abóbora
PROCEDURE ExportTXTCMYK;
VAR
fileName : STRING;
hplan : HANDLE;
vcode, vnome, vcyan, vmangen, vyellow, vblack : STRING;
numRows, numColumns : INTEGER;
vlin : INTEGER;
vboo: BOOLEAN;
BEGIN
    fileName := 'Suvinil_CMYK.txt';
    Append(fileName);
    hplan := GetObject('Teste2l');
    IF (hplan <> NIL) THEN GetWSRowColumnCount(hplan, numRows, numColumns);
vlin := 2;
REPEAT
    vcode := GetCellStr(hplan, vlin, 1);
    vnome := GetCellStr(hplan, vlin, 2);
    vcyan := GetCellStr(hplan, vlin, 7);
    vmangen := GetCellStr(hplan, vlin, 8);
    vyellow := GetCellStr(hplan, vlin, 9);
    vblack := GetCellStr(hplan, vlin, 10);
    WriteLn(vcyan,vmangen,vyellow,vblack,vcode,vnome);
    WriteLn;
    {WriteLn('Teste Teste');}
    vlin := vlin+1;
UNTIL(vlin>numRows);
vboo := EOF('Teste_CMYK.txt');
Close('Teste_CMYK.txt');
END;
RUN (ExportTXTCMYK);
Sherwin-Williams Colors.xml
Edited by Paulo Renan Ferrari
I think this is due to your system language settings using the comma as the decimal separator.
Probably the most straight forward way to solve this is to convert to strings using the format you want and then writing the strings to the file. That way you will have full control over the output.
Num2Str should get you a string value, but it will probably still have the comma as the decimal separator. Loop through using something like the following:
ChangePos:=Pos(',',MyStringVariable);
Delete(MyStringVariable,ChangePos,1);
Insert(MyStringVariable,Changepos,'.');
HTH.
