Quatrefoil windows?
michaelk
Anybody have a good method of putting quatrefoil windows in round walls?
Trying to do one that is a quatrefoil shape inset into the wall, not a molding applied to the wall.  I've tried putting a simple multiple extrude converted to a generic solid in the 3D Wall Hole Component.
It works, but it brings VW to a crawl.
Anybody got a better way?
Kevin
I actually tried other geometry first.  EAPs wouldn't render at all, but extrudes would.  So I tried a multiple extrude.  It worked, but slowed the drawing way down.  Converting to a generic solid didn't help.
I actually suspect it's a problem with the walls being round.  It's the same project where I discovered this bug.  I haven't had time to experiment, but I suspect it would be better if I used a straight wall or didn't have a window that was in a position on the round wall that triggers this bug.
Maybe I just need to talk the client into a square tower 🙂
2 minutes ago, michaelk said:
Ha!  User error.  I changed the 3D wall hole component from a multiple extrude to a generic solid in one of the quatrefoil window symbols.
Just not the one I was using.
The generic solid still had more vertices than necessary.  Lofted it and it's better.
Ha I was just about to try making one myself to test it out 🙂
Glad you found a solution. The round wall / window at 0 degree thing is almost certainly a bug. It may be related to how Vectorworks draws circles since I've had issues crossing the zero point with other geometry too.
Kevin
