kenpayson Posted August 13, 2018 Share Posted August 13, 2018 I created windows and doors intended to have clear glass. The glass shows up opaque in open GL. I tried making the glazing class 'Glass-Clear' with no fill for that class. I tried having no fill for the object, but that only makes the sashes clear, the glass remains opaque. I tried 'None' for the glazing class in the settings. Nothing works. I tried importing a clear glass window from another file, but it shows up clear in the original file and opaque in the new one. I solved this in the past and can't remember how. Any and all suggestions will be appreciated. Thanks, Quote Link to comment
Vectorworks, Inc Employee Rob Books Posted August 13, 2018 Vectorworks, Inc Employee Share Posted August 13, 2018 check your open GL options to see if use texture is on. it is at the bottom of the render dropdown. Quote Link to comment
kenpayson Posted August 13, 2018 Author Share Posted August 13, 2018 Thanks Rob - I checked and unchecked that box but it didn't seem to make any difference. Quote Link to comment
Andy Broomell Posted August 13, 2018 Share Posted August 13, 2018 In your window settings under Classes, make sure the glazing is actually assigned to the appropriate class. Quote Link to comment
zoomer Posted August 13, 2018 Share Posted August 13, 2018 I think I had a similar problem in the past with Windows because the Glass Class was not set to use Class Attributes or Texture attributes. Quote Link to comment
wingchudesign Posted August 24, 2018 Share Posted August 24, 2018 Also, make sure that your glass texture has the necessary attributes to be clear. You can find the texture and the means to adjust its settings in the resource manager. Quote Link to comment
Vectorworks, Inc Employee Luis M Ruiz Posted September 4, 2018 Vectorworks, Inc Employee Share Posted September 4, 2018 What is your percentage for transparency? if past 100%, then objects show solid in OpenGL but look super in renderworks Quote Link to comment
kenpayson Posted September 4, 2018 Author Share Posted September 4, 2018 Thanks for all the help - I reopened the file and set the glazing-clear class on and it seems to have worked this time. Quote Link to comment
