I am struggling to get some dimensions working. I am using hybrid or 3d symbols to construct stage drawings. I am then creating viewports on sheets for the various plates I need to print. The problem is I can't seem to get the dimensions on the sheet layer to attach to the symbols. The result is when i make a change to the location of the symbols on my drawing layer the dimensions don't update on the sheet layer.
How do I get the dimensions to attach to the symbols and or dynamically update?
I should note that if I attach the dimension to a standard object (line, square etc..) those dimensions get a little green square and do update correctly.
AceRoehrborn
Thanks for any advice.
2 answers to this question
