Mark Aceto Posted August 9, 2018 Share Posted August 9, 2018 Using the default settings to export a DWG from either a plan or 3D view, then importing that export into a new file, lots of 3D geometry is missing from symbols and PIO's. The drawing is a fresh file with only objects that I have drawn. Exporting to 3DM has no issues whatsoever. Has anyone else experienced this, and found a solution? Quote Link to comment
mikekow80 Posted August 28, 2018 Share Posted August 28, 2018 I will second this problem. Simple extruded square works fine but symbols and everything else isn't working. I've tried all the old tricks as well and played with what seems like every option combination of settings with no success. If exported from a 3d view it at least picks up the height, but still flattening the symbols. I feel like this is a newer problem since the scenic guy has never complained about this before. I'll call the mothership tomorrow see if they have any answers. Quote Link to comment
