Alt+F4 Posted August 9, 2018 Share Posted August 9, 2018 Is there a possibility to reference the time a rendering has taken (preferably in the OIP of a VP)? Quote Link to comment
rDesign Posted August 9, 2018 Share Posted August 9, 2018 Here’s a link to a previous wishlist item requesting this: 2 Quote Link to comment
danm01 Posted August 15, 2018 Share Posted August 15, 2018 It's not ideal, but one thing you can do is Publish the sheet layers containing the viewports. Vectorworks generates a publish log that tells you how long each sheet takes to produce. I say it's not ideal because there's no opportunity to cancel. But if you want to kick off a few different versions and go get some coffee... The log file report looks like this (file name removed): Quote ITEM FILE FORMAT RESULT SOURCE FILE ---- ----------- -------------------- ------------- 1-Site Plan PDF ( 4.90s) SUCCESS 2-Seating Plan PDF ( 4.75s) SUCCESS 3-Production Plan PDF ( 3.07s) SUCCESS 4-Rigging Plot PDF ( 4.30s) SUCCESS 5-Elevations PDF ( 22.15s) SUCCESS 6-House Drape & Riser Plot PDF ( 1.75s) SUCCESS I do think having a way to track render time data within the program would be extremely valuable, and I've mentioned to Vectorworks team members on the phone and at trade shows. Generally the answer is something like, "well, you can see it on the lower right once the viewport has rendered." -Dan 3 Quote Link to comment
trashcan Posted November 21, 2021 Share Posted November 21, 2021 Brutal, but good work around @danm01 Quote Link to comment
