roof component bound offset
@mike11968 - there are a few issues with your roof construction here, but I'm sticking to just the top junction issue, you need the Connect/Combine tool
Starting with a 'faulty' junction..
1200468899_ScreenShot2018-08-04at18_14_22.thumb.png.5e046c21506c5ab336b0bd1f1956baff.png
Use the tool and the appropriate options for the tool (have a play around with the options to get acquainted)...
1429813957_ScreenShot2018-08-04at18_14_52.thumb.png.c5d987a283a9fa6f5fd4928407fcb14f.png
Then, highlight one section of roof and drag to highlight the opposing section to join the two..
553680651_ScreenShot2018-08-04at18_15_17.thumb.png.9ccf2636a6c3341b06c4062da5d9e951.png
to provide the fix you need...
618786280_ScreenShot2018-08-04at18_15_33.thumb.png.69cbfd08c30a693d93f8e730c8e4fed7.png
You can carry out this operation from any viewing position that you can see both pieces conveniently.
I assume this is what you need.
-------EDIT
Sorry, (reading your OP more carefully!!) I have misunderstood your problem - you are talking about just top component.
I'm guessing something said 'don't go there again' after an earlier similar question.....
You'll see some of the issues.
Edited by Gadzooks
1 minute ago, mike11968 said:
did not trim the top roof component
Agreed - hence my Edit of that post. This is a complication Roof Faces just can't deal with.
Read on and use Roof rather than faces. (As discussed) this should work for you.
  • 3 weeks later...
I asked a while ago if this could be fixed. The issue with the create roof tool is if you ungroup it (for whatever reason) you are back to square 1 with the original issue above. I have reverted back to using 2 roof faces a thin tile overhang and a thicker lower rafter. It's very time consuming. Also has implications for working drawing detail. Argh!
