Christiaan Posted August 1, 2018 Share Posted August 1, 2018 Any ideas how to fix this? Area in red shouldn't be visible. Quote Link to comment
0 line-weight Posted August 1, 2018 Share Posted August 1, 2018 can you post the file? 1 Quote Link to comment
0 AlanW Posted August 1, 2018 Share Posted August 1, 2018 @ChristiaanHi is your model set to triangles or smooth mesh? 1 Quote Link to comment
0 twk Posted August 2, 2018 Share Posted August 2, 2018 @Christiaan, also, is there a site modifier boundary object, encompassing the modifer? I think its called Grade Limits now. 1 Quote Link to comment
0 Christiaan Posted August 2, 2018 Author Share Posted August 2, 2018 13 hours ago, Alan Woodwell said: @ChristiaanHi is your model set to triangles or smooth mesh? Indeed it is. Only happens on this mode. Quote Link to comment
0 Christiaan Posted August 2, 2018 Author Share Posted August 2, 2018 (edited) Here's the file: test.vwx Edited August 2, 2018 by Christiaan Quote Link to comment
0 line-weight Posted August 2, 2018 Share Posted August 2, 2018 1 hour ago, Christiaan said: Here's the file: test.vwx Changing yours from mesh to extruded contour seems to make it behave as it should. I tried pasting the site model from one of my current projects into your file. Then I copied your crop object and applied it to my site model. It seemed to work OK on mine , didn't produce the same result as yours - whether in mesh or contour mode. Fiddling with yours, I found that offsetting the crop object inwards by 1000 made the messy bit disappear. I think there's something it doesn't like about the crop object being outside the extent of the survey data. I've a feeling I've come up against something like this in the past. 1 Quote Link to comment
0 Christiaan Posted August 2, 2018 Author Share Posted August 2, 2018 (edited) 5 minutes ago, line-weight said: I think there's something it doesn't like about the crop object being outside the extent of the survey data. I've a feeling I've come up against something like this in the past. Yes, I think you're spot on. That crop is the boundary of the site so I think I'll just add some interpolated levels around that line. Thanks for spotting that. Edited August 2, 2018 by Christiaan Quote Link to comment
0 Christiaan Posted August 2, 2018 Author Share Posted August 2, 2018 Hmm, can we not mark a post as 'solved question'? Quote Link to comment
Christiaan
8 answers to this question
