BJRobinson
Drawing stepped retaining walls in 3D
Can anyone point me to a video that explains how to draw retaining walls stepping up a sloping site with returns that taper up from the base. Similar to the attached plan.
Hmmh,
the way VW DTM and modifiers work and what options are there,
I think I would prefer to cut out the whole area with a large single
Modifier - to be free to Model all Walls, Stairs, Walkways and
Ground Fills from scratch like it would be standard Architecture
or a Building.
But I assume you would like to have existing and proposed Volums
for calculations with out doing heavy math in tables .....
If VW Modifiers required,
I think I would fill each island with Polygons by bucket,
apply an inset of 0,5 cm for each (that they don't touch).
This should work for easy for al level Objects,
work ok for all (simple) sloped areas,
while the ground filled areas may require to convert them to 3D
Polys or use of stake objects to form a complex, random sloped
nature feeling.
8 hours ago, zoomer said:
Hmmh,
or a Building.
nature feeling.
Thanks zoomer.
I'm relatively new to VW. So I'll have to read through your reply a few times to understand it all.
BJRobinson,
What I have found is that you can use contours with slopes at the top and bottom of walls to get the desired effect. If you want to have the wall slope you should then take you wall tool and modify the top by moving the grips.
13 hours ago, BJRobinson said:
Thanks zoomer.
Oh sorry, thought it is about that special problem here.
If you are not very familiar with VW DTM I'ld recommend the wonderful
VW Video get started series about VW Landmark on youtube.
Which explain all things like the different terrain modifiers.
Also I misunderstood the Walls as I thought they would be level to
create terraces.
But I think there was an option to make their bottom follow a terrain
and you can manipulate and add their peaks on top and bottom manually.
